We are running version 14.3 LTS. The IT side of our company uses HP monitors We are hoping to be able to use those same monitors on our Delta V system. The monitors we are trying to use are HP EliteDisplay E223. We are hoping to set them up with 1920 X 1080 resolution. We have a quad monitor set up in a square configuration.
No matter what we try we the graphics from the two top screens, monitors 1 and 4 , shows up on the monitors below, into monitors 2, and 3. The part that shows on the lower monitors are a bit of the top of upper monitor. We have attempted to adjust the layout using the KBA NK-1700-0207 which involves some convoluted setting using regedit of a matrix using the resolution of the monitors. We attempted to "nudge" the graphics into place using this matrix but could not get that work.
A similar offset happens when we try a dual monitor setup. However the two monitor offset is very small compared to the issue on the quad setup.
One other thing to note is everything works fine if we use a dual set up or the quad set up in a horizontal configuration.
My question is a two part. Has anyone been successful in using a non Dell monitor and if so how did you set it up? Maybe Deltav just does not like HP monitors???
In reply to Andre Dicaire:
In reply to doug bray:
You may also want to check that the Scale and layout is set to 100%. I had almost the same issue after installing a new non-Dell monitor when it is set to other than 100%.
In reply to Eric_Brousseau:
In reply to Neil Castro:
