I'm trying to setup some text to blink from one color to a different color. I can setup the color functions to change the color. I can setup the condition to choose if it blinks. But, I can't figure out how to also have it blink between two different colors. This was easy to do in the animations dialog in Configure with the "blink to" column. I can't figure it out in Graphics Studio.
Hi TreyB,
Is the animation below what you are trying to achieve?
If this is what you need, take a look at the Text Color Animation option for Blink Animation, this option is available to Text or Datalinks, under the Text tab configuration properties:
Configure both On and Off colors and the text will alternate between those 2 colors when the condition is True.
I hope this helps!
Camilo
Camilo Fadul | DeltaV Solution Marketing Director
https://www.linkedin.com/in/cfadul
