I have a system where the number of signals for the input and output assembly instance exceeds the LDT limit of 100 tags.
I tried creating a second LDT with same assembly instances and I am able to read/write using this configuration. Only issue is I get following warning while downloading the PDT.
Does configuring this way cause any issues?
Is there a workaround where I don't get the warning message?
Andre Dicaire Matt Forbis
