We aare facing an issue in a LSDO out signal connected to the heater TRIP signal.
For the past five days exactly at 9:40 PM bad signal is originated from a LSDO block.
The BAD signal is active for only one second and goes to normal state. In the filed RED LED is let for one second in the DO charms.
After one second all output signal and charms are back to normal.
I thought that this is because of the BAD signal in the charm and I changed the charm but still the BAD signal is appeared in the same time. T
here is no timer implemented in the logic. Please give your suggestion to rectify this issue.
- Bryce H. Elliott, P.E.
In reply to Tadeu Batista:
In reply to arulgeorge:
