Hi Forum,
I would like to create a function to automatic set the DC/STATE_MASKS.STATEINx fields of a dedicated input / output.
If that dedicated IO_IN_x input is not configured then the function shall set the STATE_MASKS input to ignore after a download.
Reference-parameter can check via the PARAMETER.$REF as string if there is any reference, #IGNORE or empty.
I don't know how to check this IO_IN_x / IO_OUT_x Parameters online within an action in that CM.
Thank You and Best Regards,
Michael
