Hi All,
I restored a complete set of project graphics onto a new development/testing proplus by copying the entire Graphics-iFix directory into place in DVData. This results in a script error when trying to start DeltaV Operate. I've made changes to various settings including thisnode.SCU but no major improvement. My questions are:
1. Is there a defined procedure for restoring graphics backups to a new pro+?
2. Is there a well-defined explanation anywhere of how the various settings, layout files and scripts all interact when Operate is starting? It is a bit convoluted and I've only had to adjust minor settings in the past.
3. My monitor resolution is 1920 x 1080 which isn't supported by versions < 13.3.1. Will this simply result in the graphics looking squashed/stretched, or cause errors when trying to run?
Any advice on any or all of these is much appreciated.
In reply to Cedric Dawnhawk:
'A compile error was detected in a script that was about to run. The script will not be started.' Error Number: 0 (00000000). Gets to 14% starting Operate Config. I have fiddled around and successfully had Operate Configure start, but then get the same error trying to start Operate Run. I know this is related to me copying global script/settings and/or config files into place, but I'm struggling to find the actual error. There is obviously something about the settings files I am missing.
In reply to Len Walker:
APGSchedules is NOT a schedule from Emerson and removing/disabling might cause some issues with your system so I agree with Cedric that you need to find out what it was doing before removing totally.
Based on your comment that within that schedule contained a named item AlarmSummaryServiceRawDataCollection I would assume it has to do with some Alarm Management logic that is either internal to the workstation/system (ISA 18.2 alarm counts) or an external system to get Alarm information but names are deceiving and it can be doing something completely different
