Coriolis Mass flow meter is well know flow technology for fluids measurement ... but I'd like post a new topic to be open discussed- What is dfference between gas measurement and liquid measurement ? is there any Coriolis's advantage on Gas measurement opposed other flow technologies ? Why?
Not sure I know the entire answer on this - but part of it may be related to the fact that Gas flow has a lower density - so the mass flow is typically less. Direct Mass would still have advantages in Gas flows being measured in mass or Base Volumetric unts (like SCFH or NM3/Hr) - but the accuracy of the meter will not be as high as liquid.
In reply to BillGraber:
Coriolis works gr8 for Gas measurement (with AGA 11 compliant), as it has lesser dependence on P & T (AGA 8 super comprisibility). This is gr8 solution for all NG applications (Except cross country pipeline)... Few distinction POV (Point of View) picth :
1. Nearly as accuate as online Ultrasonic (even without Wet Cal)
2. It is very compact, simplified installation with smaller skid footprint & lesser TCO.
3. Economic SG analyzer - 3098 will get easy transition from mass to volume (Doesn't required online GC)
AND lastly, it doesn't bring higher pressure drop, nor expensive and available up to 16" process connection. Questions?
In reply to Caracas27:
In reply to Marc Buttler:
