I do not have any idea about data sheet of multiphase flow transmitter, is there any referance?
Regards
Best Regards,
In reply to Rachelle McWright:
In reply to MOH:
Hi @MOH. Can you tell me the family of flow meter? Is it a 2600 (about a metre tall) or one of the older, larger meters? That will help me to get you the right data sheet.
If it is a 2600 then you can find the data sheet at http://www2.emersonprocess.com/siteadmincenter/PM%20Roxar%20Documents/Flow%20Metering/Roxar%20Multiphase%20meter%202600%20Datasheet.pdf
Please let me know what you need and I, or a MPFM specialist, will get you more information.
Andrew Dennant
In reply to Andrew Dennant:
hi Andrew
if i want to order flow meter, i fill datasheet and send it to suppliers, but in this case, i do not have any datasheet. and i can not find any referance about limitation.fore example, if used for crude oil wells, wells situation change during
service life ( rate of water, oil and gas change), i want to be sure, meter remain in operating area (accurate region)
In reply to Ninan Mathews:
Adding Семен Жуйков (Semyon Zhuykov) (Semyon Zhuykov) to this email who manages our Russian group in the EE365 community which can also be found in the page footer, for reference. Ninan Mathews, please attach the datasheet to your reply and Семен Жуйков (Semyon Zhuykov) can follow up by connecting you to an expert in your local area as needed.
