Hello the community.
I would like to use a table with two temperature and concentration variables.
And I want to make a while loop that allows to compare the temperature measurement and the concentration with the values defined in the table and to choose the value of the corresponding density.
And I want to use two dynamic references to browse rows and columns.
Thank you in advance.
Best regards.
Butler faith.
At first I agreed with Chips answer, but then I realized that you are asking for 2 inputs to generate 1 output. The Signal Characterizer doesn't do that as far as I can tell.
As I see it (off the cuff) you have a few options:
For Option #1, Search in books online for how to access "Matrix Parameter References." I think this will get you what you want without the burden of Dynamic References.
If you really want to go the Dynamic References direction to do this, you can certainly do that, but:
I hope this helps,Dave
In reply to dave_marshall:
