I'm trying to determine the correct and most efficient way of modifying the names of control modules and equipment modules nested inside a Unit instance created from a unit class. I've read several posts related to creating module templates and equipment templates based on their respective classes and then using bulk edit to create the instances with unique names. Is there an equivalent method for unit classes? I didn't see a way to create a unit template.
Here are a couple screenshots of an example of what I'm trying to do. The first images is a simple NC valve control module class. This NC valve will be nested inside a unit module class.
The second image is the Unit class with nested control module classes.
The third image is an instance of the unit module.
Is there a process using Bulk edit to modify the names of the control modules and equipment modules inside a unit instance? Will this method also work for control modules nested inside an equipment module contained inside a unit module?
Wes
