Limitation of max samples values in Excel Add-in
I am using Deltav 12.3 excel addin to get process history data to excel. But I found out that there is limitation in "RAW data function" in maximum samples of 65536. Is possible to change this limitation somehow or is there any other possibility how to get bigger amount of process history data to excel?
Thank you
  • In reply to Dragonfly:
    You're right , I found this information "For now, DeltaV Reporter has a limitation of 65,536 rows regardless of Excel version"
    SO you have work around if you really need more.
    Suggestions :
    - Use DCVCHDUMP ( less user friendly but very powerfull) ( you can build macro in excel to export the command and import the result
    - split your addin queries into severall shorter period or increase the sample time to reduce line number. At the end working with much more 65536 lines in excel will be not very efficient also , Excel will be very slow to manipulate these data
