Automatic Export of FHX for a control module
Hi All,
Is there a way to run a scheduled task to export individual objects in fhx format?
  • I don't believe so. The command line export would export the entire database.
    What is your goal? How would a scheduled export task be used to export individual items from the database? Curious as to what you want to accomplish to see if there is another approach.
  • In reply to Andre Dicaire:
    No real reason at the moment, the question was more of a result of a conversation. I remember hearing that Agile Docs would automatically keep documents up to date, I assume they read the specific objects of interest (fhx), not the entire database export?
  • In reply to Nicholas Stom:
    As far as my experience goes, if you place an fhx into the input folder of AgileDoc (manually or in an automated way), it parses it and saves the data in an SQL database. It however does not automatically generate documents, needs to be triggered manually. You should also check whether what you're trying to do is supported by AgileDoc, in my experience it's used more for recipes.
