Downloading Changed Setup Data to Redundant Batch Executive server
Hi All,
I need to download "Changed Setup Data" to a redundant Batch Executive (BE) to see if it resolves a couple of issues with the standby server.
The issue(s) I'm trying to resolve are the standby as indicating as not available (following a reboot) and also the CSS license not being recognized by the standby server.
I see there are a few posts on here regarding downloading Changed Setup Data to systems that are active production systems.
Usually the answer is there is no risk to downloading Changed Setup Data i.e. the process will not be impacted in anyway.
Does this also apply to downloading to the BE node?
Thanks
