I have a valve type that looks like a custom valve there are roughly 20 of these valves and this morning they all went black, instead of red and green and have tried everything to get them to go back to how they were. RED CLOSED, Green open. This error has only happened on 2 of the 6 operator stations i have the others are fine. The pro-plus is fine i tried downloading to these machines from the pro-plus and it does not take or work. I tried taking the graphics from the graphics i fix library and this does not work either.
In reply to AdrianOffield:
In reply to Neal Shea:
Sounds like the issue has already propagated amongst your nodes, DV Operate only reads those files on a restart, so it could of happened anytime previously.
The advice given is for persons familiar with the basics of Deltav, they are not intended for new users. Obviously if SCU is unfamiliar and if this is a live system, you should really be logging a call with GSC who will walk you through each step.
I would be reluctant to make any changes to a system without understanding which color table is missing, and to be honest you need to know where the SCU is pointing before being able to pinpoint the correct user.fxg or siglobals.fxg to troubleshoot.
Call GSC, its a simple process to resolve, but as you can see, manual changes have the potential to cause bigger problems.
