Hello DeltaV forum.
I am working in building a syntq orchestration to read NIR spectra data from an instrument which will be used to predict moisture content. I managed to connect syntq to deltav tags through OPC and I think I can send the NIR data to a tag, but I don't know how to send array data to a tag since I always work with scalar values. The need for array data stems from simca online needs to read data to predict a moisture content which subsequently feed to a controller to close a control loop. Please find below a sketch of what I currently have.
The question is, Is there a possibility to write array data to a deltav tag through OPC?
It's reasonable for me to ask this as well: Is there a simpler way to achieve what I need? I'm open to all ideas.
Thank you immensely for your help.
In reply to Julian Navas:
Julian,
I'm surprised to hear that the integration between synTQ and SIMCA is not straightforward. By all indications, synTQ touts the interoperability of their software. (see their diagram below).
I just dug up the following on using the SimAPI for connecting synTQ to SIMCA online - https://umetrics.com/sites/default/files/syntq_simapi_installation_doc.pdf.
I also found this interesting article at synTQs site. https://www.syntq.com/researchers-use-optimal-syntq-and-model-based-control-to-transform-the-efficiency-of-pharmaceutical-drying-processes/#prettyPhoto
In the system, synTQ® was used to control the inline NIR sensor that analysed the material in the dryer during operation. The spectra recorded by the sensor were passed to an analysis package (SIMCA QP), which used them to generate predictions about the current moisture content of the material. This data was passed back to the synTQ® package, which processed it and passed it on in turn to the dryer’s Delta V control system, using the OPC protocol. Delta V then used the predicted data to alter the inlet temperature and air flow rate in the dryer, according to an empirically derived process model.
This sounds exactly like your case study (perhaps it IS your case study!) Bottom line, maybe a question for your synTQ representative.
