The following observations were logged by our customer, during an FAT which require clarifications, that require detail knowledge of the DeltaV product.
Observation 1: SD to SZ Communication Delay
Both the primary and secondary ACN cables were disconnected followed by reconnection after a suitable Delay. Please can you explain why the delays?
It was observed that the Non-Secure parameter was delayed between and 30 seconds and 1 minute to cascade to CSLS and update following reconnection.
Also both Primary ACN between SZ and SD controllers was disconnected causing communications to be via the secondary ACN, it was observed that if one of the two Secondary ACN Link is disconnected a bad status is generated on the non-secure parameter. Note that one connection remain connected. It was also observed that if both secondary ACN is disconnected and one primary is also disconnected bad status is NOT generated on the non-secure parameter. Please can explain why bad status was generated?
Observation 2: LSN to GSN Communications Failure
When network cables between LSN and GSN is disconnected multiple evet messages were generated that were quite confusing, customer wishes to identify the most critical message that could be used to alert the operator, please can you confirm which message should be used?
Observation 3: Communication Between LSNBs
Our test system includes a setup of two LSNBs, but the target system will have several LSNBs, it was observed during testing that a failure between one LSNB and GSN, both LSNB generates an error message, customer is concerned that for a system with several LSNB if each LSNB generates an error message for a single failure then fault finding would be difficult, please can you explain how the message are being generated and do we expect a message from every LSNB in the system for a single failure?
Observation 4: LSNB Communication Delay
It was observed that there is a 7 seconds delay before a communications failure event is generated following link disconnection to the LSNB, customer believes this could lead to SOE being misleading when diagnosing a shutdown event, please can you explain why the delay?
