I am upgrading our DeltaV and one of the items in Read before you start is this:
When upgrading from DeltaV v12.2 or before, Microsoft SQL is upgraded to SQL 2012. To perform this upgrade, the services SQL Server (MSSQL) and SQL Server Agent (SQLAGENT) must have the 'Log on as' option set to Local System account. Any other setting causes the upgrade of Microsoft SQL to not complete successfully. To verify this setting, open Administrative Tools | Services. Right click the service name and select Properties. On the Log On tab, verify that the 'Log on as' option is set to Local System account.
But when I checked my Services, I found out this:
Which of the SQL Server item above is the one referring in Read Before You Start?
Do I need to change the account name under the "Log on as" for all the SQL Server to Local System?
And lastly, do I have to do this before or after the upgrade?
Thanks for answering.
In reply to Tim Alexander:
In reply to Rein:
