How to change the maximum number of lines on DataLink?
Hello, on DataLink for the alphanumeric data, the maximum number of lines that can you entered is 5.
How to change the maximum number of lines that you want to display in alpha-numerically formatted Data link?
  • You could try this instead of using the datalink dialog.
    From the system-tree right-click on the datalink and select 'property window ...'. In the new window that opens change the value of MaxLines to 12 or other value you want.
