Hello All,
Trying to learn Delta V and integration, your insight would be greatly appreciated.
What are some of the best practices when integrating a Modbus TCP/IP or EtherNet/IP networks with a large device count (i.e. 120 devices) into the DeltaV systems?
From what I've seen, most experts here are utilizing the VIM2 to tie the networks together. That being said, I believe the VIM2 only supports 32 devices and/or 128 Datasets.
So does that mean I would have to add (4) 2-wide carrier containing the power supplies and VIM2 to the left of the controller to be able to support that device count or am I missing something?
If the above assumption is correct, adding these VIMs on a new build is fine, but what about existing panels, they normally don't have this extra space. How is this over come?
Thank again
In reply to DBacker:
In reply to Michael Krispin:
In reply to István Orbán:
In reply to Gsr13k:
In reply to Michael Moody:
