HI,
I require the operator to have to enter the same figure twice into the faceplate for charge weight set points before it is accepted.
From a safety point of view this would reduce the amount of errors.
I have been told this is possible where I would program it like when you have to add a password at a internet site, you have two fields first insert password the second field is confirm password, if they don´t match it won´t work.
Can anyone expand on this, changing a faceplate is easily done, the programming behind it is where I come unstuck, or let me know where I would find the information I require?
any help is greatly appreciated.
Thank you in advance.
Lee Wren
Program it like when you have to add a password at a internet site, you have two fields first insert password the second field is confirm password, if they don´t match it won´t work.
In reply to MCrisler:
In reply to Lee W.:
