I am trying to convert a Time value, defined as string parameter, to a time format and I am having trouble with the Time_to_str function.
e.g.
Parameters
- TIME defined as String with the value 142789657
- TIME_STR defined as String
If I use in a Calc block the following expression:
'/TIME_STR.CV' := TIME_TO_STR (%A, '/TIME')
the result is an empty parameter. It seems that the parameter '/TIME' is not in the right format. What can I do to make thjis work?
In reply to Matt Stoner:
In reply to Chris Kominar:
