Bulkexporting (all possible) parameters from a set of class based modules is successfull including alarm information.
When the result is imported to another configuration which has to be updated, the ImportExportProgress.log indicates:
Updating Type: MODULE: Name: LA-821: WARNING: Cannot change alarm bindings for a class based module2: WARNING: Unable to set alarm parameter path3: WARNING: IMPORT ERROR: IMPORT of MODULE with key LA-82 FAILED at line:3346 column:34. This could cause other serious import errors for related items in this file. Import is now resuming at the next item in the file.
No changes have been made to the modules related to these lines.
Is it possible to change alarm setting of class based modules?
Note: the alarm settings can be changed from DeltaV Explorer.
In reply to Maarten van der Waal:
