Hello,
I use DC block to start and stop motor and monitor running status.
Sometimes, while motor is running (set point equal START, and PV is equal to RUNNING), something electrical happens and the RUNNING status is loss resulting in DC1/FAIL_ACTIVE true after about 10 seconds per our design.
The status of the DC blocks becomes set point equal START, and PV is equal to STOPPED. The Operator acknowledges the FAIL ACTIVE alarm.
The problem is sometimes Operator forgets to change set point to STOP, so if some other logic triggers that motor to START, nothing happens because set point is already START.
Is there a setting in the DC function block I can set such that anytime a fail alarm occurs the set point is set to STOP? Of course I can build some logic to set the set point to STOP if this type of failure occurs, but I would think DeltaV already have something like this.
Thanks for your help in advance.
In reply to MCrisler:
