I am in the process of migrating Profibus Interfaces to Ethernet IP Interface. The problem is that I have more than 800 device signals that I need to extract the reference from it, document the information through mapping schedules and convert and remap to the EIOC. Do you guys know a way export all the reference to an specific card/channels/device signal so I can get a CSV of it? It’s going to be a waste of time going signal by signal to get the reference for the whole system.
Thanks for your collaboration
P.S.: If I select the Card and I click IO Configuration, I will get all the references in a orderly fashion that I will be expecting. The problem doesn’t allow me to copy and paste or export, only print and the print-out report isn’t good.
In reply to Anas Mustafa:
Hello Jose, As Anas and Lost Engineer recommended, you would like to look into using DeltaV BulkEdit feature. It will help export these data into a excel format. Here is a link for your reference to implement this utility.
click on>> DeltaV BulkEdit
In reply to LostEngineer0:
In reply to Neil Castro:
In reply to JoseCarias:
