Hello,
I'm trying to extract data from the Continuous Historian for the sake of performing miscellaneous mass-data analysis, including but not limited to Alarm Rationalization. We have V14.3.1.
I have successfully extracted data for one point at a time using the DVCHDUMP utility. Documentation for the utility seems a bit scattered, but if you play with it a bit you can sort of find your way around. I can make this tool do what I need it to do by creating a script that will run this utility over and over for all of the tags I desire, saving the results in text files in a folder.
However, I have some reservations:
I tried pulling one of the .DB files from D:\DeltaVHistory and opening it locally but it appears to be encrypted or unrecognized by the DB Browser I tried.
Does anyone have any sage advice that may help me get data in a better way?
Josh
In reply to LaurentB:
In reply to Joshua Granger:
