Hi everyone,
I'm looking for some help in managing transitions of slave controllers to cascade / bumpless transfer.
In cases where a slave controller receives remote CAS IN from a master controller or calc block and the master OP cannot be back-initialised, what options are available in DeltaV to manage the 'bump' due to difference between the CAS In (output of master block) and the current slave SP?
(for whatever reason - an example might be a split range controller with 2 outputs, but one slave has been in auto or manual)
Is there a standard PID function block feature and parameter to 'limit' the rate at which the slave SP is aligned with the CAS IN (when placed in CAS)?
Any general guidance / pointers on managing this aspect of bumpless transfer in DeltaV would be appreciated.
Thanks in advance!
In reply to James Beall:
