The register address are as follows:40900 to 40934-floating40936,40937,40938-8 bit integer40939 to 40949-floatingTried the following things:1:Configured 3 datasets as per this list but datasets went bad2:Configured 40900 to 40936 as floating-dataset 1 became healthy and got proper data for these registers,dataset 2 also became healthy,but dataset 3 still bad3:Configured 3rd dataset as 40939 to 40949 as floating but they were bad(Diagnostic status-error response-installed resp msg size)4:Configured from 40940 to 40950 as floating & datasets turned healthy however received junk data(No 3rd party vendor available for support,no serial cable present to test with modsim)What could be the issue and how to resolve
