I have a 24VDC contactor that I need to turn on/off. What type of charm should I use? I have DO 24VDC and DO HSS available but if I try with the former, nothing happens when I send the on signal. With the DO HSS, the contactor gets activated but it turns off himself.
I'm using a DO block to send the on/off signal.
Any advices?
Hello Carlos, Without knowing your wiring setup and power setup, I am guessing you have having some sort power setup issue. Here is a commissioning document that ou can verify 24 VDO and HSS wiring and setup verification. Maybe this will help with troubleshooting your issue. Let me know if your wiring and confirguration is correct and still are having issue. I will look at other possible cause.
Commissioning Charms
In reply to Andre Dicaire:
In reply to Carlos Velazquez:
