I assigned a device tag to an I/O reference in an AI function block. The device tag had not been allocated to any I/O channel. When I go to the I/O (conventional or CHARMS) and browse for a device tag the device tag does not appear in the Unassigned I/O References. Shouldn't it be there? If I select All instead of Unassigned I/O References I can see the DST listed amongst the rest but with no Channel assigned as expected. If I click Find from Unassigned I/O References and select Object Type 'I/O Reference', the device tag is listed.
Am I misunderstanding something? This is DeltaV version 12.3
