I am working on some dynamic alarm masking and investigating the masking and unmasking behavior. The currently functionality on the project following alarm unmasking is -
- If inactive, the alarm does not appear on the alarm list. This is correct and what is expected.
- If active, the alarm comes back into the alarm list time stamped with current time and Acknowledged status - this is an issue as there is a high chance that the operator could miss it as it is already Acknowleged!
I was wondering if anyone has any previous experience/suggestions about dealing with this behavior and how the logic could be amended/edited to make sure the alarm, if still active, comes back as Unacknowledged following unmasking?
Thanks for your help.
You have two options and maybe only one if you also want the horn to become active again as well as alarm being unacknowledged.
Either case requires that you change all the modules/alarms and then download unfortunately.
In reply to Matt Stoner:
