Control and Access DeltaV from Other Country
Hi All,
If  we want to propose the solution  to control and access DeltaV form other country. In case in the existing DeltaV system, we have Batch Executive, EWS and OWS, and then want to configure remotely in the other country.
Kindly please advice, what is the best solution for that matter (what are the licenses and Hardware needed) ?.
Thanks
Al Amin
  • I believe using DeltaV Executive Portal is the best solution, it will gives you below options :
    - Securely view your process remotely – on desktops or Windows tablets via the Internet
    - Convert displays with minimal rework
    - Easily create dashboards to view just the information you need
    - Combine information from multiple systems and historians into a single view
    Introduction.
    Check this out for more information:
    www2.emersonprocess.com/.../PDS_Executive_Portal.pdf
  • Look for a TS-Server and a RDP solution. It will solve all your needs.
  • In reply to Hisham:
    These DeltaV features and functions will meet your needs:
    DeltaV Remote Access Server
    DeltaV Remote Client
    And make friends with your IT department ... Wishing you success!
    Hi Hisham,
    Thanks for your reply,
    By the way, on that PDS I didn't get any info that DeltaV Executive Portal available to control and Configure Engineering and Batch workstations.
  • In reply to Tomas_Rosen:
    Hi Tomas,
    please correct me if i'm wrong, if we are using the RDP Solution, we can't do anything on the existing right?
  • In reply to MC_Chow:
    Hi Chow,
    please advice, if we are using the DeltaV RAS, then we can connect Remote Workstation on EWS and APS/Batch, so we have two capabilities (Engineering and Batch Control), but if we want to use the satellite for their connection, can the EWS do that? I only have reference that APS can connect via satellite, for EWS I don't have any clue.
