need to import my plant pic folder into delta operate to simulate but each time i copied the pic folder and paste into graphics -ifix and open deltav operate i get a compile error and visual basic scrips opens. my plant pic pictures is on version 7.2 while simulate is 11.3 for the fhx system files i did a migrate and import everything works fine except deltav operate run. pls advice
In reply to Pieter Degier:
In reply to molly:
Hello molly~ Thanks for adding your expertise to the community. If you would like to add a photo to your post, follow these quick steps:
1. Under YOU posts and replies there is a blue button that reads More, choose EDIT
2. Put the curser where you want the image to land and Choose the Insert/Edit Media Button from the toolbar above the test field and you'll see this graphic, upload and choose insert
3 Click Insert
4. Hit Post
Tip: If you are creating or editing a reply (versus a post, you will want to choose USE RICH TEXT FOMATTING at the bottom right of the grey box where you enter text- this will bring up the graphic tool bar that allows you to format your text, add photo and video, etc.)
Best Regards,
