PID output holding during AO failure.
Dear all,
I am facing an issue while working with the foundation fieldbus system.
In my control strategy I have attached both PID & AO block with the control valve positioner FF blocks. It is working perfectly in normal condition. Now the issue is:  For any reason if my field device malfunctions and sends a bad signal via AO block,  PID is holding its last output value. But once the AO become healthy PID output becomes Zero(0) which is badly affecting the process control.
I need a solution so that while AO switches from a bad to healthy state PID output remains unchanged until user intervention.
Please guide me if there is any specific configuration needed in PID or AO block or anything else.
Thanks and Regards.
