Hello Everyone,
I have to interface mynah with a simplex flow computer.Prior to that i am testing it with a modbus tester.Through this i am only able to read the values but not able to write.Not even the values of my mynah resgisters are changing(which should at the first place).If i keep my output dataset in a readback form,even then it is not able to write,however if now i change the register in the modbus simulator,the values are read back in my mynah registers but the reverse is not done.There is no error in the deltav diagnostics and the status of datasets are good.How to troubleshoot this?
Karma doesn't have any menu, you get serve what you deserve.
In reply to Kartik29:
In reply to VANSH DEVRAJ:
