Hi All,
Currently using DeltaV 10.3.1 and was trying to trend the BATCH_ID parameter in the Unit itself. I've configured is as below
Enabled, "5 minutes" Sampling period with Display Representation as "Automatic" in the General tab.Under the Advanced Tab, the following was set, Parameter field path : BATCH_ID.CVData Characteristic : ContinuousData Compression : Deviation - "1" and Collect - "8 hours"
I have download the Continuous historian as well as the Unit. Currently, under the PHV, all I can see is a "Pt created" instead of the batch ID that was manually entered. Under Watchit, I was able to see the batch ID but it give me a RT_CONVERSION_ERROR.
Would like to check if there is anything to be done about it?
Regards
