Hello to all
According to delta V,we have to order a separate DST license for serial data.my question is that how can order correct license for serial data transfer.for example please advise me for ordering for serial data DST calculation including 500 digital and 300 analog signals.
thanks in Advance.
In reply to Moji:
Since V9.3 the serial license requirement has been removed so you shouldn't need an additional license. I believe Tyler is referring to a landing module, where you address all the serial registers in this module, with control modules referencing the landing module. See below.
When you create your dataset, you'll select input or output:
On the DeltaV tab, you'll select the signal type:
