Hello,
We have a graphic that allows the operator to click on a check-box to enable or disable all the alarms that are in a unit module.
I was wondering how I can write to this check-box from a control studio module. I want to use this to disable alarms on equipment that isn't in service, and re-enable it when the equipment is re-enabled.
You cannot animate the value of the Microsoft Forms Check Box OLE object, but you can copy a checkbox object from a faceplate or detail display and customize. Look at AI_dt.grf as an example and the Sim Enable checkbox. You would customize the _Click events for rctCBOff and grpCBOn, and the visibility animations for the same. Alternatively, You could create two overlapping push button objects and use visibility to determine which button and its underlying code are available to the operator.
Thanks to Matt Stoner for the suggestion of using the checkbox object from the faceplate and detail displays.
