Hi Experts,
I am trying to export the data from the level with yellow mark (Please see picture attached):
I have tried the existing export function, unfortunately I can only export the "structure" but not all the elements and data.
Do you think DeltaV has such kind of "export-all-element" feature ? Or any possible way to retrieve the data by access to the database where DeltaV Explorer connecting ?
Thank you very much !
In reply to engwei:
Have you try using Bulk Edit user define export? It can be exported into excel. Here is the link for more info on Bulk Edit. http://www2.emersonprocess.com/siteadmincenter/PM%20DeltaV%20Documents/Whitepapers/WP_Bulk_Edit.pdf Hope this helps
In reply to Tinh Phan:
In reply to gamella:
If you export whole database or just a part of it, have a look to <this tool> able to convert FHX to XML file; because the emerson utility doesn't works correctly ... when it works.
Regards. Jack
In reply to Jack_France:
