we have upgraded our DCS from 6.3 to 9.3 but in the deltav operate when the application is run we have problem with modules that they use DC block for example pumps and motors and valves .after calling the motor or valves faceplates pop up error as following will be appear .
how can we solve this error ?
This error message does not give much information. You could for the time being set the permission in iFix to get to the VBE code, so when this error pops up, you will see the code where this error occurs. With this information you may be able to change the code or load a more recent Emerson code file (.fxg).
Purnendu Saptarshi
Automation Engineer | Skellig Automation US LLC | Greater Boston Area, MA
