From where I can find the wiring diagram of DeltaV IO's card.
VE4003S2B6
VE4003S2B3
VE4005S2B1
VE4001S2T2B4
VE4002S1T2B5
SIS
VS3202
You can find this information within DeltaV Books Online.
Once you have Books Online open:
->Expand Hardware Installation
->Expand DeltaV S-series and CHARMs Hardware Reference
->Expand S-series I/O interface specifications
->Expand S-series classic I/O cards specifications
->Select the appropriate card
Another way to get there is to go to the Search Tab and search for "AI 8-channel 4-20 mA HART card specifications" (include the quotes) and select the first item. If you go back to the Contents tab, you should be in the correct location.
VE4003S2B6 Analog Input Card: 16 Channels 4-20 mA, HARTVE4003S2B3 Analog Input Card: 8 Channels 4-20 mA, HART, 4-wireVE4005S2B1 Analog Output Card: 8 Channels 4-20 mA, HARTVE4001S2T2B4 Discrete Input Card: 32 Channels, 24 Vdc, Dry ContactVE4002S1T2B5 Discrete Output Card, 32 Channels, 24 Vdc, High Side
The last one (VS3202-Redundant Logic Solver) will be found in a different location within Books Online and starting from the root level:
->Expand DeltaV Safety Instrumented Systems
->Expand Smart Logic Solver (SLS 1508) SIS Systems
->Expand DeltaV SLS 1508 hardware
->Expand Logic Solver and channel specification
->Select the channel specification that is required
Another way to get there is to go to Search Tab and search for "Simplex Logic Solver termination block" (include the quotes) and select the first item. If you go back to the Contents tab, you should be in the correct location.
