Delta V data appears "&&&&&"
Hello, I work in El Angel Sugar Mill , we have Delta V 11.3.1
one workstation begin a problen with data that appers in screens.  For about 10 to 15 seconds appers "&&&&&&" .
the process continue good during this seconds.
I checked "alarms and event", i only saw ACN switches for this workstation.
what else can I check.
thanks
  • Hi Irving,
    It looks like this particular workstation is loosing network connections. By default "&&&&" is an indicative of unknown source which could be due to loss of connection with the network (controller data available on network) or a wrongly configured source.
    Following are suggested checks:
    1. Ping 10.4.0.6 and 10.8.0.6 or other IP addresses on the network to ensure the machine in question is connected to the network.
    2. Download the machine from Pro+ (complete download)
    3. Try running the workstation configuration again on this machine.
    4. Check network cables and replace them if necessary.
    Thanks.
    Purnendu Saptarshi
    Automation Engineer | Skellig Automation US LLC | Greater Boston Area, MA
  • In reply to Purnendu Saptarshi:
    thanks for your help.
    I download the machine from the Pro+ and we have two days without the bad condition .
