We are in the middle of Alarm Management. We are trying to reduce the number of alarms for operations, of course. We have created a new Area and assigned the CIOC and Device to the new area, attempting to get the hardware alarms on a session and not the operator workstation, but it is not working. Maybe someone can provide some support on how to do this. Under the Pro+ the new areas are under the remote sessions. Just to repeat myself, we want the process alarms on the operator workstation and the device hardware alarms on the session.
In reply to Lucky:
Is your pro-plus also a chronicle? Can you see the alarms in the pro plus chronicle?
What priority are your hardware alarms set to? Is it possible they are set to an auto-acknowledging type?
Open the AlarmFilt display and verify that the Checkbox for the associated area(s) are checked and also not greyed out.
If this is greyed out, close operate, logoff as DeltaV user (not the machine) and then re-open workspace and log back in as a DeltaV user.
Here is a pic of what it should look like - except the area names of course :)
In reply to Matt Stoner:
Do the alarms appear in Process History View? Have you downloaded changed setup data to the pro-plus since making the changes? Using WATCHIT, can you view the value of THISUSER/ALARMS[n] where n is 1 - 100 and determine if your alarms appear anywhere in this array? (my bracket [ n ] got converted to a stupid emoticon, sorry) Are you able to see the hardware/device alarms on the (thick client) operator stations?
