Delta V to Koyo PLC interface
I am looking for reccomendations for the best method to interface a Koyo DL 205 PLC to the Delta V network. Does anyone have any experience (good or bad) they would like to share?
Thanks in advance for your time.
  • In reply to Roman Kostuniak:
    Thanks for the suggestion, Roman.
    Dgrippa,
    Here at MYNAH,  you can communicate with our Modbus TCP Virtual IO Module (IOD-4101) but you will need to add a H2-ECOM100 to your CPU.
    See  www.automationdirect.com.au/.../dl205.html for the following info:
    Ethernet Communications Modules
    The Ethernet Communication (ECOM) Modules represent a price breakthrough for high-speed peer-to-peer networking of PLCs. No longer are you forced to designate a single PLC to be the network master. Any PLC can initiate communications with any other PLC. Link your PLCs with PCs using industry standard MODBUS TCP/IP protocol (using H2-ECOM100) connected through standard cables, hubs, and repeaters. Or, use our KEPDirect I/O Server to link to your favorite HMI/SCADA, data historian, MES or ERP software to DirectLOGIC PLCs. Our LookoutDirect HMI and our DataWorx data collection software include ECOM drivers. DirectSOFT32 Programming Software can be used to monitor or update the program in any DirectLOGIC PLC on the network.
    The D2-260, D2-250-1 and D2-240 CPUs support the H2-ECOM Ethernet communications module. Any PLC on an ECOM network can initiate communications with another PLC or use DirectSOFT32 to program any PLC on the network.
    The H2-ECOM module supports the industry standard 10BaseT with an RJ45 port. The H2-ECOM-F has ST-style bayonet connectors for 10BaseFL fiber optic connections.
    Ethernet Communications Modules can be used for:
    • High-speed peer-to-peer networking of PLCs
    • Fast updates with DirectSOFT32 Programming Software
    • High-performance access for Human Machine Interface (HMI), ERP, MES or other Windows-based software
    • Industry standard MODBUS TCP/IP Client/Server Protocol (H2-ECOM100)
    • Free SDK for custom drivers
    • Easy setup
    Feel free to contact me if we can help you!  +1.636.728.2036 or Noelle.hasser@mynah.com
