Replacing dynamos
I have a situation where I need to recreate 50 some odd graphics with new standards. I have the custom dynamo sets that were used.  I need to get them all with updated dynamos.. OH well, use the update dynamo utility. Except that only works on dynamos of the same name, etc. So, I tried a find and replace on the graphic to rename the dynamos on the graphic with the name of the dynamo i want to replace it with. The problem then is that I get an error for "invalid number of parameters" because the dynamos are obviously different and were built different. It does create the dynamo on the page, but it's just a generic dynamo thrown in the center with no MODULE associated with it. The existing doesn't get updated. I've been able to replace the old dynamo on the graphic by striipping away the extra stuff until it has the same basic stuff.. then the update dynamo swaps it with the new.. but drilling down into the dynamos on the grahpic is more work than just deleting and pasting the new one and updating the MODULE tag.
Any ideas to streamline this?  I'm extremely pressed for time and building from scratch is going to be a real problem.
Thanks
