Hello,
Please see picutres below.
How do I add BFI1/First_Out parameter to Event Chronicle so I can see CND condition block caused the interlock to activate?
Thank you so much Youssef,
I will try this and respond with results. Hopefully, the Event Chronicle will show me when BFI1/OUT is True (1) and the corresponding the BFI1/FIRST_OUT value. [:D]
In reply to DCS Newbie:
In reply to Bill Sayers:
See the product data sheet:
http://www2.emersonprocess.com/siteadmincenter/PM%20DeltaV%20Documents/ProductDataSheets/PDS_EventChronicle.pdf
Description Model Number
Event Chronicle VE2143
The Event Chronicle requires Process History View (part of the History View Suite) to view the collected alarms and events.
The Event Chronicle is included in the ProfessionalPLUS Station and Professional Station Software Suite(s).
If installing on an APP station, the alarms and events for the app station must include the areas you wish to monitor, which means the app station must have sufficient base App Station licensing for this.
