What is the preferred method of activating custom schedules? We have a custom schedule, but it doesn't seem to load with DV Operate Run, regardless of assigning it in the background startup files, it only seem to work if we manually open the schedule before switching to run mode. Do schedules have to be called from initialization routines? If so, which routines should I call it from? (this is a foreground schedule)
Adrian,
I assume by "background startup files" you are talking about using frsOpenUserSchedule "<Your Scheduler>.evs" in UserSettings.grf, this a correct assumption?
I have not done it in a long time but this method worked the last time that I tried it.
Matt
In reply to AdrianOffield:
Hello Everybody,
how do I start a User Schedule?
Kind regards
In reply to LostEngineer0:
Refer to the following BOL article:
The Scheduler
www3.emersonprocess.com/.../adv_scheduler.html
In reply to Mike Link:
Hi thank you for your helpful answers.
Problem solvers unite! :)
Best Regards,
