Trying to bulk import our Alarm Help information from our Alarm Management meetings into DeltaV. I'm running into an issue because some of our "Recommended Actions" are more than 255 characters and the Bulk Import bombs out. Anyone else have this issue and is there a work around (other than leaving those particular ones > 255 characters out of the bulk import file and manually copying them in)?
In reply to Shannon Jistel:
Have you tried importing from a flat CSV file, rather than through ODBC? If it's a problem with the ODBC code in the import, you may at least be able to get around it in the short term that way.
