DeltaV Simulate 7.4 License Key
I have installed version 7.4 simulate as I have a client who is still running this version.   I previously had it running a few years back but for whatever reason when I go into DeltaV setup it will not look at the A: drive (floppy) to load the license key.
I have an external usb Floppy drive.  The computer see's the drive within My Computer and also I am able to access the files on the drive.  However when I click LOAD in the setup I get nothing showing up.  I have tried disconnecting the drive and reconnecting it then I click on load as soon as the drive starts accessing the disk in the drive.  This has also been unsuccessful.
Any help would be greatly appreciated.
  • Oops! My bad. I have a USB version of the dongle. Make sure your VM is allowed to see LPT1.
    From:        "Louise Foster" <bounce-LFoster@community.emerson.com>
    To:        <DeltaV@community.emerson.com>
    Date:        03/19/2013 04:52 PM
    Subject:        RE: [EE365 DeltaV Track] DeltaV Simulate 7.4 License Key
    Unfortunatly I am not seeing the Hardlock identifier withing the removable devices.  I think this is because it is on the LPT1.
  • In reply to SBPosey:
    @ Louise : Please, detail your hardware machine, because suggestions depend on it. i.e. :
    - HardLock key type : Parallel or USB port
    - Are you using a virtual machine (VMware or Windows virtual machine) or a direct machine ?
    - Windows versioning
  • In reply to Jack_France:
    Hi, check if you have the Alladin drivers installed.
    In VMvare, you do not see your physical hard drive!! only the "shared"  folder you have to specify in WM.
    You can copy the license through this folder to the WM virtual harddrive.
    Niklas Flykt
    Klinkmann Oy
    nikfly@gmail.com
  • In reply to Niklas Flykt:
    I think Emerson will swap your LPT dongle for a USB one. I would ask your local rep about this.
