64 bit Systems available with DeltaV version 12
I am looking for specs of 64 bit PCs tested with DeltaV 12 systems
I need to order and only specs available is of 32 bit PCs.
  • All current models of Emerson supplied PC’s are 64bit, the difference is in the operating system. Check the latest WP.
    From: mohdismail.khan [mailto:bounce-mohdismailkhan@community.emerson.com]
    Sent: Friday, February 22, 2013 12:26 PM
    Subject: [EE365 DeltaV Track] 64 bit Systems available with DeltaV version 12
  • In reply to AdrianOffield:
    Are the following systems supported by DeltaV version 12
    [1] Dell Precision R5500, TPM with Windows(R) 7 Professional 64 bit
    [2] PowerEdge R720 , Microsoft(R) Windows(R) Server 2008 x64 R2 SP1 Standard Edition Media,English
    White paper does not mention above models.
    Are the above models already tested with DeltaV version 12?
  • If it’s not listed then generally it isn’t supported…not to say it won’t run, but GSC won’t offer much support if you use non-approved hardware.
    Looking at the latest workstation hardware datasheet http://www2.emersonprocess.com/siteadmincenter/PM%20DeltaV%20Documents/ProductDataSheets/PDS_WkstationHdware.pdf, it lists the R5500 and R720 as supported for 11.3 and newer DeltaV versions.
    If you purchased from Emerson then consider it supported.
    Sent: Monday, February 25, 2013 11:03 AM
    Subject: RE: [EE365 DeltaV Track] 64 bit Systems available with DeltaV version 12
