I am wondering if anyone knows what is causing this issue, or how to fix it.
We have just set up a 4-monitor workstation. When we run DeltaV Operate all 4 main pictures and toolbars etc. load, however they all load one on top of another on monitor #1. If only the 2 monitors on the first graphics card are plugged in, the 2 window view works fine (Pictures loaded into each window). Any other combination and it does the same overlapping as the 4 monitor setup.
Info about the setup:
I suspect the problem is that we are currently setting up this system using an SI key and therefore it is not finding the correct multi-monitor license file. We have previously set up other 4 monitor stations running on a normal consumer license with no issues.
Installing Hotfix DeltaV_1131_WS_06_CSS worked.
Closer inspection revealed that the Graphics cards had been changed since the last working setup we did.
Thank you for your help everyone.
